Ana içeriğe geç
Asus V6800V Hard Drive Replacement
Neye ihtiyacın var
  1. Asus V6800V Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Asus V6800V Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Remove the two screws using a Phillips #0 screwdriver.
  2. Asus V6800V Hard Drive Replacement: adım 2, 2 resimden 1. Asus V6800V Hard Drive Replacement: adım 2, 2 resimden 2.
    • Pry open the case using an iFixit opening tool.
    • Actual hard drive is not shown in the second image.
  3. Asus V6800V Hard Drive Replacement: adım 3, 2 resimden 1. Asus V6800V Hard Drive Replacement: adım 3, 2 resimden 2.
    • The highlighted area is where your hard drive would be. Slide it out away from its slot and pull it gently to remove.
    • Second image shows what it should look like once you remove the hard drive.
Sonuç
Jong Park
114 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S2G9
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 2,938
