Giriş
Removing the keyboard is a useful way to clean it, or it can be replaced if broken.
The keyboard needs to be removed if you wish to remove the top part of the case for further maintenance of the computer.
Parçalar
Hiçbir parçaya gerek yok.
First, the screws on the bottom need to be removed first.
  • First, the screws on the bottom need to be removed first.
Yorum Ekle
There are 4 small tabs holding the keyboard in place. These are located above the F1, F5, F10, and Ins keys. pic 69
  • There are 4 small tabs holding the keyboard in place. These are located above the F1, F5, F10, and Ins keys. pic 69
Yorum Ekle
Starting on one side, use a finger or small tool to press the tab into the chassis of the computer. The edge of the keyboard will elevate. 72, 73 Starting on one side, use a finger or small tool to press the tab into the chassis of the computer. The edge of the keyboard will elevate. 72, 73
  • Starting on one side, use a finger or small tool to press the tab into the chassis of the computer. The edge of the keyboard will elevate. 72, 73
Yorum Ekle
Continue down the keyboard. The keyboard will be noticeably elevated. 82, 83
  • Continue down the keyboard. The keyboard will be noticeably elevated. 82, 83
Yorum Ekle
Once all of the tabs are indented, the keyboard will eject itself, remaining elevated. 388
  • Once all of the tabs are indented, the keyboard will eject itself, remaining elevated. 388
Yorum Ekle
Partially remove the keyboard by sliding the elevated keyboard towards the screen. Don't remove it all of the way, as we need to remove it's cable first. 389
  • Partially remove the keyboard by sliding the elevated keyboard towards the screen. Don't remove it all of the way, as we need to remove it's cable first. 389
Yorum Ekle
To remove the cable holding the keyboard in, flip the keyboard upside down. 391 Using your forefinger and thumb, pinch both sides of the cable and pull away from the connector. 396, 401 You now have the keyboard separated from the computer. If you wish to clean it, you can use compressed air to blow the dirt out. You now have the keyboard separated from the computer. If you wish to clean it, you can use compressed air to blow the dirt out.
  • To remove the cable holding the keyboard in, flip the keyboard upside down. 391 Using your forefinger and thumb, pinch both sides of the cable and pull away from the connector. 396, 401
  • You now have the keyboard separated from the computer. If you wish to clean it, you can use compressed air to blow the dirt out.
Yorum Ekle
Sonuç
6 başka kişi bu kılavuzu tamamladı.
Brian Tubb
280 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S2G9
5 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 3
Tüm Zamanlar: 2,171
