Ana içeriğe geç
Asus V6800V Keyboard Replacement
Neye ihtiyacın var
  1. Asus V6800V Keyboard Replacement, Battery: adım 1, 2 resimden 1. Asus V6800V Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Keyboard Replacement, Keyboard: adım 2, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the two screws from the case.
    • These screws should have a "K" symbol next to them.
  3. Asus V6800V Keyboard Replacement: adım 3, 3 resimden 1. Asus V6800V Keyboard Replacement: adım 3, 3 resimden 2. Asus V6800V Keyboard Replacement: adım 3, 3 resimden 3.
    • Locate the four tabs above the F1, F10, INSERT, and between the F5 and F6 keys.
    • Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
    • Once all four tabs have been released, the top half of the keyboard should be free.
  4. Asus V6800V Keyboard Replacement: adım 4, 2 resimden 1. Asus V6800V Keyboard Replacement: adım 4, 2 resimden 2.
    • Pull the keyboard up from the top at a 45 degree angle. Place it upside down on the touchpad.
    • Pull the wide ribbon cable laterally from its socket on the motherboard to free the keyboard.
Sonuç
Steven
32 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S2G9
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 4,970
