Ana içeriğe geç
Asus V6800V Lower Case Replacement
Neye ihtiyacın var
  1. Asus V6800V Lower Case Replacement, Battery: adım 1, 2 resimden 1. Asus V6800V Lower Case Replacement, Battery: adım 1, 2 resimden 2.
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Lower Case Replacement, Keyboard: adım 2, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the two screws from the case.
    • These screws should have a "K" symbol next to them.
  3. Asus V6800V Lower Case Replacement: adım 3, 3 resimden 1. Asus V6800V Lower Case Replacement: adım 3, 3 resimden 2. Asus V6800V Lower Case Replacement: adım 3, 3 resimden 3.
    • Locate the four tabs above the F1, F10, INSERT, and between the F5 and F6 keys.
    • Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
    • Once all four tabs have been released, the top half of the keyboard should be free.
  4. Asus V6800V Lower Case Replacement: adım 4, 2 resimden 1. Asus V6800V Lower Case Replacement: adım 4, 2 resimden 2.
    • Pull the keyboard up from the top at a 45 degree angle. Place it upside down on the touchpad.
    • Pull the wide ribbon cable laterally from its socket on the motherboard to free the keyboard.
  5. Asus V6800V Lower Case Replacement, Lower Case: adım 5, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the screws at the bottom of the chassis to remove the top panel.
    • This will allow the lower case to be removed from the rest of the computer.
  6. Asus V6800V Lower Case Replacement: adım 6, 1 resimden 1.
    • Remove the six screws from below the keyboard with a Phillips #0 screwdriver.
  7. Asus V6800V Lower Case Replacement: adım 7, 2 resimden 1. Asus V6800V Lower Case Replacement: adım 7, 2 resimden 2.
    • Use your fingernails or a pry tool to gently separate both halves of the case. Begin at the front and work around the entire case.
    • Be cautious not to damage the cables that connect both sides of the case.
  8. Asus V6800V Lower Case Replacement: adım 8, 3 resimden 1. Asus V6800V Lower Case Replacement: adım 8, 3 resimden 2. Asus V6800V Lower Case Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the internal cables from front to back.
    • Use your fingers to gently remove the cables from their sockets.
    • The cables that connect the display to the main chassis are difficult to pull out using your fingers. A tool, such as tweezers, may be needed.
  9. Asus V6800V Lower Case Replacement: adım 9, 1 resimden 1.
    • After separating the top and bottom halves of the case, lay them flat on the work area.
Sonuç
Brian Tubb
272 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S2G9
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 7,748
