Ana içeriğe geç
Asus V6800V RAM Replacement
Neye ihtiyacın var
  1. Asus V6800V RAM Replacement, Battery: adım 1, 2 resimden 1. Asus V6800V RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V RAM Replacement, RAM: adım 2, 1 resimden 1.
    • On the back panel unscrew highlighted screws and carefully put them to the side as not to lose them.
  3. Asus V6800V RAM Replacement: adım 3, 1 resimden 1.
    • Locate the RAM chip and the two metal tabs holding it in place.
  4. Asus V6800V RAM Replacement: adım 4, 1 resimden 1.
    • Carefully use your thumbs to push out the metal tabs and the RAM should spring up.
  5. Asus V6800V RAM Replacement: adım 5, 1 resimden 1.
    • After the ram has sprung up, carefully grab the edges with your fingers and gently pull straight out.
  6. Asus V6800V RAM Replacement: adım 6, 1 resimden 1.
    • After you have gotten either more RAM or replacement RAM line up the pins and slot (highlighted red) in the RAM card with the pin on the computer.
    • Carefully insert the new ram in at the same angle that you removed it at.
    • The other side of the RAM slot is a place for more RAM if you want to put more in.
Sonuç
Connor
34 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S2G9
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 3,349
