Giriş
If your Asus V6800V is experiencing issues with the speakers, such as distorted sound, low volume, or even complete failure, use this guide to help you replace the speakers on your own.
Before making this repair, make sure there are no other solutions and the replacement is necessary. Try cleaning your speaker ports, and also check the audio setting to ensure your volume is all the way up. If all fails a speaker replacement is necessary.
This guide will require you to remove the battery, the keyboard, and the top cover of your laptop. Some of these steps require the use of a screwdriver.
Make sure your device is powered off, and take your time to ensure a successful battery replacement.
Neye ihtiyacın var
Place the computer upside down.
Using your thumbs, slide both latches away from each other (towards the outside).
Push the battery out with your fingers.
Using a Phillips #0 screwdriver, remove the screws at the bottom of the chassis to remove the top panel.
Remove the four screws using a Phillips #0 screwdriver.
Remove the protective metal plates with your hands.
Bir başkası bu kılavuzu tamamladı.
