Ana içeriğe geç
Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement
Neye ihtiyacın var
  1. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement, Back Panel: adım 1, 1 resimden 1.
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: adım 2, 3 resimden 1. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: adım 2, 3 resimden 2. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: adım 3, 3 resimden 1. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: adım 3, 3 resimden 2. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: adım 3, 3 resimden 3.
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement, Headphone Jack and USB Port: adım 4, 2 resimden 1. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement, Headphone Jack and USB Port: adım 4, 2 resimden 2.
    • Disconnect the ribbon cable located above the battery.
    • Flip up the locking tab on the Zero Insertion Force (ZIF) connector, then slide the cable away.
  5. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: adım 5, 2 resimden 1. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: adım 5, 2 resimden 2.
    • Disconnect the small white ribbon cable that is connected to the unit that holds the USB and headphone jack.
    • First, lift the white tab that locks onto the blue tab and then pull the cable out by the blue tab.
  6. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: adım 6, 2 resimden 1. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: adım 6, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove the two 2 mm screws on the top left and bottom left of the component with the headphone jack and USB port.
  7. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: adım 7, 2 resimden 1. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: adım 7, 2 resimden 2.
    • Remove the headphone jack and USB printed circuit board by lifting it directly up and out of the laptop.
Sonuç
Melanie
280 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S8-G1, Bailey Spring 2019 UMass Dartmouth, Team S8-G1, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S8G1
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 603
