Ana içeriğe geç
Asus VivoBook E203MA-TBCL432B Motherboard Replacement
Neye ihtiyacın var
  1. Asus VivoBook E203MA-TBCL432B Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 2, 3 resimden 1. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 2, 3 resimden 2. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 3, 3 resimden 1. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 3, 3 resimden 2. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 3, 3 resimden 3.
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B Motherboard Replacement, Battery: adım 4, 3 resimden 1. Asus VivoBook E203MA-TBCL432B Motherboard Replacement, Battery: adım 4, 3 resimden 2. Asus VivoBook E203MA-TBCL432B Motherboard Replacement, Battery: adım 4, 3 resimden 3.
    • Now that the back panel is removed you can clearly see the battery and all of its connectors.
    • Begin by removing the silver ribbon cable along the back of the battery.
    • To disconnect it from the motherboard, lift the black tab on the Zero Insertion Force (ZIF) connector up and pull the cable away using the blue tab.
    • Disconnect the ribbon cable from the left side in the same way.
  5. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the red and black wire along the bottom of the battery.
    • This does not need to be disconnected, only removed from the clamps along the bottom of the battery.
  6. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 6, 2 resimden 1. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 6, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws located at the top and left side of the battery.
  7. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 7, 3 resimden 1. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 7, 3 resimden 2. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 7, 3 resimden 3.
    • Gently lift the battery being mindful of the one cable still connected to the motherboard.
    • With the battery lifted, pull the remaining connector going to the motherboard up, it should come out with little force.
  8. Asus VivoBook E203MA-TBCL432B Motherboard Replacement, Motherboard: adım 8, 1 resimden 1.
    • Disconnect the small black and red bundled cable by lifting it directly up from the connector on the motherboard.
  9. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 9, 2 resimden 1. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 9, 2 resimden 2.
    • Disconnect the black ribbon cable in the center of the motherboard by first lifting the black tab and then pulling the cable free.
  10. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 10, 3 resimden 1. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 10, 3 resimden 2. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 10, 3 resimden 3.
    • Remove the coaxial connector from the motherboard.
    • Grasp the wire close to where it connects to the motherboard.
    • Pull up and away from the motherboard until the connector is no longer attached to the motherboard.
  11. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 11, 2 resimden 1. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 11, 2 resimden 2.
    • At the top of the motherboard there is a connector that is taped in place.
    • Peel back the tape so that it is no longer in contact with the motherboard.
    • Gently pull the connector out from its socket.
  12. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 12, 2 resimden 1. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 12, 2 resimden 2.
    • Now that all the cables are disconnected from the motherboard, you can begin to remove the screws holding the motherboard in place.
    • Use a Philips #0 screwdriver to remove the six 2 mm screws.
  13. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 13, 3 resimden 1. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 13, 3 resimden 2. Asus VivoBook E203MA-TBCL432B Motherboard Replacement: adım 13, 3 resimden 3.
    • Lift the motherboard away from the computer while allowing the ribbon cable in the middle to fall through its cutout.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Brad
539 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S8-G1, Bailey Spring 2019 UMass Dartmouth, Team S8-G1, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S8G1
3 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Can we have a tutorial on how to remove the storage from it?
CJ-1-2-3 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 35
Her zaman: 2,278
