Ana içeriğe geç
Asus VivoBook E203MA-TBCL432B Speaker Replacement
Neye ihtiyacın var
  1. Asus VivoBook E203MA-TBCL432B Speaker Replacement, Back Panel: adım 1, 1 resimden 1.
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Speaker Replacement: adım 2, 3 resimden 1. Asus VivoBook E203MA-TBCL432B Speaker Replacement: adım 2, 3 resimden 2. Asus VivoBook E203MA-TBCL432B Speaker Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Speaker Replacement: adım 3, 3 resimden 1. Asus VivoBook E203MA-TBCL432B Speaker Replacement: adım 3, 3 resimden 2. Asus VivoBook E203MA-TBCL432B Speaker Replacement: adım 3, 3 resimden 3.
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B Speaker Replacement, Speaker: adım 4, 3 resimden 1. Asus VivoBook E203MA-TBCL432B Speaker Replacement, Speaker: adım 4, 3 resimden 2. Asus VivoBook E203MA-TBCL432B Speaker Replacement, Speaker: adım 4, 3 resimden 3.
    • Using the iFixit opening tool, pry up and remove the battery connector from the motherboard.
    • Using the iFixit opening tool again, carefully wedge the tool under a corner of the speaker connector on the motherboard that is connected by three wires (colored red, black, and white).
    • Slowly pry the connector up without damaging the motherboard.
  5. Asus VivoBook E203MA-TBCL432B Speaker Replacement: adım 5, 3 resimden 1. Asus VivoBook E203MA-TBCL432B Speaker Replacement: adım 5, 3 resimden 2. Asus VivoBook E203MA-TBCL432B Speaker Replacement: adım 5, 3 resimden 3.
    • Using a Phillips #00 screwdriver, remove the four 2.0 mm screws near the edge opposite of the hinge.
    • Insert the iFixit opening tool underneath the red and black wire and remove the wire from the small clasps.
  6. Asus VivoBook E203MA-TBCL432B Speaker Replacement: adım 6, 2 resimden 1. Asus VivoBook E203MA-TBCL432B Speaker Replacement: adım 6, 2 resimden 2.
    • Insert the iFixit opening tool underneath the speaker on the right side. Gently pry the speaker up to remove.
    • Repeat the step above for the opposite speaker. Then, carefully set both speakers off to the side.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Khadijah Sulail
415 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G3, Wilson Fall 2019 IUPUI, Team S3-G3, Wilson Fall 2019 üyesi
IUPUI-WILSON-F19S3G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 331
