Ana içeriğe geç
Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement
Neye ihtiyacın var
  1. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement, Hard Disk Drive: adım 1, 1 resimden 1.
    • Disconnect laptop from the power supply.
  2. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the ten 6.4 mm screws from the bottom cover.
  3. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: adım 3, 2 resimden 1. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: adım 3, 2 resimden 2.
    • Use a metal or nylon spudger to pry open the back cover on all sides.
    • Remove the back cover to access the inside where the hard disk drive is located.
  4. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: adım 4, 1 resimden 1.
    • Locate the hard-drive.
    • Disconnect the hard disk drive from its connectors, and remove the drive.
    • Place the new HDD in the same location and orientation.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Justin Martel
159 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-2, Sinclaire Spring 2022 UMass Dartmouth, Team 7-2, Sinclaire Spring 2022 üyesi
UMASSD-SINCLAIRE-S22S7G2
5 Üyeler
2 adet Kılavuz yazıldı
Bir Yorum
Hey, do you by any chance have the reference for the battery in the Asus TP410U ? Thank you!
Matt JBOM - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 32
Her zaman: 1,399
