Ana içeriğe geç
Asus VivoBook Max X541UV-BH71-CB Battery Replacement
Neye ihtiyacın var
  1. Asus VivoBook Max X541UV-BH71-CB Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop upside down so the back of the laptop faces you.
  2. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: adım 2, 3 resimden 1. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: adım 2, 3 resimden 2. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the ten 1.2 mm screws attached to the back cover of the laptop.
  3. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: adım 3, 3 resimden 1. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: adım 3, 3 resimden 2. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: adım 3, 3 resimden 3.
    • Turn the laptop upright, then open the laptop so the screen faces you.
    • Use a prying tool between the keyboard and bottom grooves to partially remove the laptop backing.
    • Do not completely remove the laptop backing because there are ribbon cables connecting the two halves.
    • It is recommended to use a plastic prying tool rather than a metal prying tool because it could potentially damage the internals of the laptop.
  4. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: adım 4, 3 resimden 1. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: adım 4, 3 resimden 2. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: adım 4, 3 resimden 3.
    • Flip the retaining flaps on both keyboard ribbon cable ZIF sockets, then carefully pull the ribbon cables out of their sockets.
    • Carefully remove the keyboard panel from the base and set it aside.
  5. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: adım 5, 3 resimden 1. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: adım 5, 3 resimden 2. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: adım 5, 3 resimden 3.
    • Remove the two 1.2 mm screws holding the battery in place using the Phillips #00 screwdriver.
  6. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: adım 6, 3 resimden 1. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: adım 6, 3 resimden 2. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: adım 6, 3 resimden 3.
    • Carefully remove the battery using a plastic opening tool.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Vivek Rana
169 İtibar
1 Kılavuz yazıldı
Bir Yorum
Does anybody has a link to buy the battery replacement? Either original or generic. Thank you!
nea-k nanea - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 41
Her zaman: 2,227
