Ana içeriğe geç
Asus VivoBook Q200E-BHI3T45 Battery Replacement
Neye ihtiyacın var
  1. Asus VivoBook Q200E-BHI3T45 Battery Replacement, Battery: adım 1, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. Asus VivoBook Q200E-BHI3T45 Battery Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to pry the back panel off.
  3. Asus VivoBook Q200E-BHI3T45 Battery Replacement: adım 3, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Battery Replacement: adım 3, 2 resimden 2.
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. Asus VivoBook Q200E-BHI3T45 Battery Replacement: adım 4, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Battery Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the ribbon cable with a pair of tweezers.
  5. Asus VivoBook Q200E-BHI3T45 Battery Replacement: adım 5, 1 resimden 1.
    • Lift and remove the battery.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Bryann Tan
877 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-2, Eyestone Fall 2016 USF Tampa, Team 16-2, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G2
3 Üyeler
4 Yorum
Hey I need help with getting the battery out with Asus Vivo-Book E406SA
James Bruzo - Yanıt
hi, i need a complete case for asus vivobook Q200E. Any help please
murphy - Yanıt
Need help getting the battery out of my E406sa
Patrick Flynn - Yanıt
could you show me how to unplug the connector without breaking it?
Deng Daniel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 43
Her zaman: 15,436
