Ana içeriğe geç
Asus VivoBook Q200E-BHI3T45 Fan Replacement
Neye ihtiyacın var
  1. Asus VivoBook Q200E-BHI3T45 Fan Replacement, Battery: adım 1, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. Asus VivoBook Q200E-BHI3T45 Fan Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to pry the back panel off.
  3. Asus VivoBook Q200E-BHI3T45 Fan Replacement: adım 3, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Fan Replacement: adım 3, 2 resimden 2.
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. Asus VivoBook Q200E-BHI3T45 Fan Replacement: adım 4, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Fan Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the ribbon cable with a pair of tweezers.
  5. Asus VivoBook Q200E-BHI3T45 Fan Replacement: adım 5, 1 resimden 1.
    • Lift and remove the battery.
  6. Asus VivoBook Q200E-BHI3T45 Fan Replacement, Fan: adım 6, 1 resimden 1.
    • Gently peel off the tape from the fan.
  7. Asus VivoBook Q200E-BHI3T45 Fan Replacement: adım 7, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Fan Replacement: adım 7, 2 resimden 2.
    • Remove five 5mm screws using a Phillips 0 screwdriver.
    • Remove the two 2mm screws with a Phillips 000 screwdriver.
  8. Asus VivoBook Q200E-BHI3T45 Fan Replacement: adım 8, 1 resimden 1.
    Satın Al
    • Disconnect the fan's power cable by pulling upward on the pin connector with a pair of tweezers.
  9. Asus VivoBook Q200E-BHI3T45 Fan Replacement: adım 9, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Fan Replacement: adım 9, 2 resimden 2.
    • Grab the sides of the fan assembly and remove it by lifting upwards.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bryann Tan
877 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-2, Eyestone Fall 2016 USF Tampa, Team 16-2, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 600
