Ana içeriğe geç
Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement
Neye ihtiyacın var
  1. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to pry the back panel off.
  3. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: adım 3, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: adım 4, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the ribbon cable with a pair of tweezers.
  5. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Lift and remove the battery.
  6. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 2.
    • Remove four 4mm screws using a Phillips 0 screwdriver.
  7. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Pull out hard drive bracket towards the edge of the laptop.
  8. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: adım 8, 3 resimden 1. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: adım 8, 3 resimden 2. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: adım 8, 3 resimden 3.
    • Remove two 3mm screws using a Phillips 0 screwdriver from each sides of the hard drive bracket. The bracket should fall off after removal.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Bryann Tan
877 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-2, Eyestone Fall 2016 USF Tampa, Team 16-2, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 5,503
