Ana içeriğe geç
Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement
Neye ihtiyacın var
  1. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement, Battery: adım 1, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement, Battery: adım 1, 2 resimden 2.
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to pry the back panel off.
  3. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: adım 3, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: adım 3, 2 resimden 2.
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: adım 4, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the ribbon cable with a pair of tweezers.
  5. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: adım 5, 1 resimden 1.
    • Lift and remove the battery.
  6. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement, Fan: adım 6, 1 resimden 1.
    • Gently peel off the tape from the fan.
  7. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: adım 7, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: adım 7, 2 resimden 2.
    • Remove five 5mm screws using a Phillips 0 screwdriver.
    • Remove the two 2mm screws with a Phillips 000 screwdriver.
  8. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: adım 8, 1 resimden 1.
    Satın Al
    • Disconnect the fan's power cable by pulling upward on the pin connector with a pair of tweezers.
  9. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: adım 9, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement: adım 9, 2 resimden 2.
    • Grab the sides of the fan assembly and remove it by lifting upwards.
  10. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement, Thermal Paste: adım 10, 2 resimden 1. Asus VivoBook Q200E-BHI3T45 Thermal Paste Replacement, Thermal Paste: adım 10, 2 resimden 2.
    • Use isopropyl alcohol and a cotton ball to clean thermal paste off the CPU and back of the heatsink.
    • Apply a drop of thermal paste on the CPU.
    • Carefully place heatsink/fan assembly back.
Sonuç
Bryann Tan
877 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-2, Eyestone Fall 2016 USF Tampa, Team 16-2, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 1,052
