Ana içeriğe geç
Asus VivoBook Q200E-BSI3T08 Battery Replacement
Neye ihtiyacın var
  1. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Battery Replacement: adım 3, 2 resimden 1. Asus VivoBook Q200E-BSI3T08 Battery Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Battery Replacement: adım 5, 3 resimden 1. Asus VivoBook Q200E-BSI3T08 Battery Replacement: adım 5, 3 resimden 2. Asus VivoBook Q200E-BSI3T08 Battery Replacement: adım 5, 3 resimden 3.
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Battery Replacement: adım 6, 2 resimden 1. Asus VivoBook Q200E-BSI3T08 Battery Replacement: adım 6, 2 resimden 2.
    • Now just lift the battery out of place.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Maxim
462 İtibar
1 Kılavuz yazıldı
Ekip
UWT Liner: Group 6 UWT Liner: Group 6 üyesi
Community
3 Üyeler
1 Kılavuz yazıldı
2Kılavuz Yorumları
Super helpful instructions. Especially mentioning which screws were different sizes, so I knew to keep the 3 different sizes for the back cover separated and noted which sizes went back where. Many thanks!
Albert Einstein - Yanıt
Great guide. Thanks!
weston.fisher - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 7,447
