Ana içeriğe geç
Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement
Neye ihtiyacın var
  1. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement, Back Panel: adım 1, 1 resimden 1.
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement: adım 3, 2 resimden 1. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement, Cooling Fan: adım 4, 1 resimden 1.
    • Unscrew the five 4.9mm screws holding the cooling fan in place using a Phillips #0 screwdriver.
  5. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement: adım 5, 1 resimden 1.
    • Unplug the power bus for the fan.
  6. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement: adım 6, 1 resimden 1.
    • Lift up and remove the cooling fan from the slot.
Sonuç
Mitchell Jackson
742 İtibar
7 adet Kılavuz yazıldı
Ekip
IUPUI, Team S4-G4, Wilson Summer 2017 IUPUI, Team S4-G4, Wilson Summer 2017 üyesi
IUPUI-WILSON-SU17S4G4
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 535
