Ana içeriğe geç
Asus VivoBook Q200E-BSI3T08 Motherboard Replacement
Neye ihtiyacın var
  1. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 3, 2 resimden 1. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 5, 3 resimden 1. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 5, 3 resimden 2. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 5, 3 resimden 3.
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 6, 2 resimden 1. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 6, 2 resimden 2.
    • Now just lift the battery out of place.
  7. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Cooling Fan: adım 7, 1 resimden 1.
    • Unscrew the five 4.9mm screws holding the cooling fan in place using a Phillips #0 screwdriver.
  8. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 8, 1 resimden 1.
    • Unplug the power bus for the fan.
  9. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 9, 1 resimden 1.
    • Lift up and remove the cooling fan from the slot.
  10. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Wireless Card: adım 10, 2 resimden 1. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Wireless Card: adım 10, 2 resimden 2.
    • Locate wireless card next to battery.
  11. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the one 4.9mm screw that holds the wireless card in place with a Phillips #00 screwdriver.
  12. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 12, 1 resimden 1.
    • Unplug the black coaxial cable from the wireless card.
  13. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 13, 1 resimden 1.
    • Pull the wireless card from connector slot.
  14. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Motherboard: adım 14, 1 resimden 1.
    • Locate the motherboard under the cooling fan.
  15. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 15, 1 resimden 1.
    • Unscrew the two 5.9mm screws on the PCB board with a Phillips #0 screwdriver.
  16. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 16, 1 resimden 1.
    • Remove the PCB board from the motherboard.
  17. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 17, 1 resimden 1.
    • Unscrew the four 5.9mm hard drive bracket screws with a Phillips #0 screwdriver.
  18. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 18, 2 resimden 1. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 18, 2 resimden 2.
    • Unscrew the four 5.9mm screws with a Phillips #0 screwdriver.
    • Next, carefully lift the LAN bracket out of the slot.
  19. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 19, 1 resimden 1.
    • Remove the five 5.9mm screws holding the motherboard in place with a Phillips #0 screwdriver.
    • Remove the five 3.5mm screws holding the motherboard with a Phillips #00 screwdriver.
  20. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 20, 1 resimden 1.
    • Carefully lift the motherboard up out of the slot.
  21. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 21, 2 resimden 1. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: adım 21, 2 resimden 2.
    • Locate and unplug the power bus from the motherboard.
    • The motherboard can now be replaced.
Sonuç
Mitchell Jackson
742 İtibar
7 adet Kılavuz yazıldı
Ekip
IUPUI, Team S4-G4, Wilson Summer 2017 IUPUI, Team S4-G4, Wilson Summer 2017 üyesi
IUPUI-WILSON-SU17S4G4
4 Üyeler
1Rehber Yorum
Very useful tutorial with nice photos indicating even different type of screws n different color..
This was more useful than a YouTube video..
I just replaced my mother board..
Thank you and God bless u for ur effort..
Gs Mobile - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 2,269
