Ana içeriğe geç
Asus VivoBook Q200E-BSI3T08 Trackpad Replacement
Neye ihtiyacın var
  1. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Back Panel: adım 1, 1 resimden 1.
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: adım 2, 1 resimden 1.
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: adım 3, 2 resimden 1. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: adım 5, 3 resimden 1. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: adım 5, 3 resimden 2. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: adım 5, 3 resimden 3.
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: adım 6, 2 resimden 1. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: adım 6, 2 resimden 2.
    • Now just lift the battery out of place.
  7. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Trackpad: adım 7, 1 resimden 1.
    • Disconnect the small blue TP(trackpad) labeled data bus.
  8. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: adım 8, 1 resimden 1.
    • Identify the ten 2.94mm screws on the metal bracket.
  9. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: adım 9, 1 resimden 1.
    • Unscrew the ten 2.94mm screws with the Philips #00 Head.
  10. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: adım 10, 1 resimden 1.
    • Remove all of the metallic tape holding the metal bracket to the components surrounding it.
  11. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: adım 11, 1 resimden 1.
    • Lift the metal bracket away from the laptop.
  12. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: adım 12, 1 resimden 1.
    • Unscrew the four 3.5mm screws with Phillips #00 Head.
    • This black plastic panel holds the trackpad in place.
  13. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: adım 13, 1 resimden 1.
    • Lift the trackpad up from the laptop and slide it out of the housing.
Sonuç
Mitchell Jackson
742 İtibar
7 adet Kılavuz yazıldı
Ekip
IUPUI, Team S4-G4, Wilson Summer 2017 IUPUI, Team S4-G4, Wilson Summer 2017 üyesi
IUPUI-WILSON-SU17S4G4
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 628
