Ana içeriğe geç
Asus VivoBook Q302LA-BHI3T09 Display Replacement
Neye ihtiyacın var
  1. Asus VivoBook Q302LA-BHI3T09 Display Replacement, Display: adım 1, 2 resimden 1. Asus VivoBook Q302LA-BHI3T09 Display Replacement, Display: adım 1, 2 resimden 2.
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
  2. Asus VivoBook Q302LA-BHI3T09 Display Replacement: adım 2, 2 resimden 1. Asus VivoBook Q302LA-BHI3T09 Display Replacement: adım 2, 2 resimden 2.
    • Insert the flat edge of the opening tool in between the back casing to remove the back casing.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus VivoBook Q302LA-BHI3T09 Display Replacement: adım 3, 2 resimden 1. Asus VivoBook Q302LA-BHI3T09 Display Replacement: adım 3, 2 resimden 2.
    • Using the JIS #0 Screwdriver, remove the five 3.0 mm screws that hold down the hard drive casing.
  4. Asus VivoBook Q302LA-BHI3T09 Display Replacement: adım 4, 3 resimden 1. Asus VivoBook Q302LA-BHI3T09 Display Replacement: adım 4, 3 resimden 2. Asus VivoBook Q302LA-BHI3T09 Display Replacement: adım 4, 3 resimden 3.
    • Lift the hard drive up and remove the power supply cable connected to it.
    • Make sure to pull on the plastic head and not the actual wires to prevent tearing them.
  5. Asus VivoBook Q302LA-BHI3T09 Display Replacement: adım 5, 2 resimden 1. Asus VivoBook Q302LA-BHI3T09 Display Replacement: adım 5, 2 resimden 2.
    • Disconnect the white and black wires attached to the Wi-Fi chip.
  6. Asus VivoBook Q302LA-BHI3T09 Display Replacement: adım 6, 3 resimden 1. Asus VivoBook Q302LA-BHI3T09 Display Replacement: adım 6, 3 resimden 2. Asus VivoBook Q302LA-BHI3T09 Display Replacement: adım 6, 3 resimden 3.
    • Remove the two adapters connecting the display to the motherboard by pulling the black plastic straps directly upwards.
  7. Asus VivoBook Q302LA-BHI3T09 Display Replacement: adım 7, 3 resimden 1. Asus VivoBook Q302LA-BHI3T09 Display Replacement: adım 7, 3 resimden 2. Asus VivoBook Q302LA-BHI3T09 Display Replacement: adım 7, 3 resimden 3.
    • Use the JIS #0 screwdriver to remove the five 5.0 mm screws connecting the display to the rest of the laptop.
Sonuç
Deric Wright
636 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G5, Eyestone Spring 2018 USF Tampa, Team S5-G5, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S5G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 277
