Giriş
The 2-in-1 touchscreen display can become unresponsive or cracked due to it being used often. If the display gets damaged or becomes unresponsive, and you determine it is not a power issue, the guide shows how to replace the entire display.
Neye ihtiyacın var
Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
Neredeyse bitti!
Sonuç
