Ana içeriğe geç
Asus VivoBook Q302LA-BHI3T09 Fan Replacement
Neye ihtiyacın var
  1. Asus VivoBook Q302LA-BHI3T09 Fan Replacement, Fan: adım 1, 2 resimden 1. Asus VivoBook Q302LA-BHI3T09 Fan Replacement, Fan: adım 1, 2 resimden 2.
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place.
  2. Asus VivoBook Q302LA-BHI3T09 Fan Replacement: adım 2, 2 resimden 1. Asus VivoBook Q302LA-BHI3T09 Fan Replacement: adım 2, 2 resimden 2.
    • Pry open the back casing using the opening tool along the side crevice.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus VivoBook Q302LA-BHI3T09 Fan Replacement: adım 3, 3 resimden 1. Asus VivoBook Q302LA-BHI3T09 Fan Replacement: adım 3, 3 resimden 2. Asus VivoBook Q302LA-BHI3T09 Fan Replacement: adım 3, 3 resimden 3.
    • Remove the following screws that mount the fan and heatsink to the motherboard:
    • Three 3.0 mm screws for the fan
    • Four 2.0 mm screws for the heatsink
    • The bottom of the heatsink will contain thermal paste. Avoid making contact with this as any dirt or oils can reduce the effectiveness of the cooler.
Sonuç
Carl Zuehlsdorf
116 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G5, Eyestone Spring 2018 USF Tampa, Team S5-G5, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S5G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 166
