Ana içeriğe geç
Giriş
This guide shows how to replace the Wi-Fi chip from the motherboard of the Asus VivoBook. The Wi-Fi chip allows the laptop to wirelessly connect to internet. In rare cases, the Wi-Fi chip may need to be replaced if a power surge fries the chip or the chip itself is defective.
  1. Before doing a repair or replacement make sure the laptop is fully shut off. Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
  2. Insert the flat edge of the opening tool in between the back casing to remove the back casing. Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
    • Insert the flat edge of the opening tool in between the back casing to remove the back casing.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Apple Watch Kitleri
    Screen and battery repairs just got easier.
    Hemen Alışveriş Yapın
    Apple Watch Kitleri
  4. Use a JIS #0 Screwdriver to remove the one 3.0 mm screw. Use a JIS #0 Screwdriver to remove the one 3.0 mm screw.
    • Use a JIS #0 Screwdriver to remove the one 3.0 mm screw.
  5. Disconnect the black and white wires that provide power and data transfer to the Wi-Fi chip. Disconnect the black and white wires that provide power and data transfer to the Wi-Fi chip.
    • Disconnect the black and white wires that provide power and data transfer to the Wi-Fi chip.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Deric Wright
636 İtibar
3 adet Kılavuz yazıldı
Takım
USF Tampa, Team S5-G5, Eyestone Spring 2018 USF Tampa, Team S5-G5, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S5G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 1
Her zaman: 75
