Ana içeriğe geç
Asus VivoBook S200E-RHI3T73 Keyboard Replacement
Neye ihtiyacın var
  1. Asus VivoBook S200E-RHI3T73 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the nine 50mm screws and lift the panel.
    • Be aware of sharp metal edges once the panel is removed.
  2. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: adım 2, 1 resimden 1.
    • Use the Phillips #0 screwdriver to remove the twelve 50mm screws around the battery.
    • Gently remove the battery to avoid damage.
  3. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: adım 3, 3 resimden 1. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: adım 3, 3 resimden 2. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the Phillips #0 screwdriver to remove the five 5mm screws around the fan.
    • Use the precision tweezers to unplug the fan cords.
    • Be cautious of pulling the cords.
  4. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: adım 4, 3 resimden 1. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: adım 4, 3 resimden 2. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: adım 4, 3 resimden 3.
    • Use the Phillips#0 screwdriver to unscrew the 3.5mm screws from around the motherboard and the 6mm screws from around the PCB.
    • Double check for unloosened screws. Bending the boards can damage the hardware.
  5. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: adım 5, 2 resimden 1. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: adım 5, 2 resimden 2.
    • Use the Phillips#0 screwdriver to remove the 50mm screws on the boarder of the metal panel.
    • Be cautious of sharp metal edges.
    • Carefully remove the panel. Without care it will bend and be difficult to reassemble.
  6. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: adım 6, 1 resimden 1.
    • Using the Phillips#0 screwdriver, remove the 50mm screws surrounding the keyboard.
    • Gently remove the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 606
