Ana içeriğe geç
Asus VivoBook S200E-RHI3T73 Screen Replacement
Neye ihtiyacın var
  1. Asus VivoBook S200E-RHI3T73 Screen Replacement, Screen: adım 1, 1 resimden 1.
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the five black 80mm Phillips #0 screws.
    • Remove the four black 50mm Phillips #0 screws.
  2. Asus VivoBook S200E-RHI3T73 Screen Replacement: adım 2, 1 resimden 1.
    • Use a metal spudger to pry the bottom panel open.
    • Be gentle around the edges.
    • Lift the back panel to expose the inside of the laptop.
  3. Asus VivoBook S200E-RHI3T73 Screen Replacement: adım 3, 1 resimden 1.
    • Use a metal spudger to remove the clear screen protector from its backing.
    • Apply ample force along the bottom of the screen protector.
  4. Asus VivoBook S200E-RHI3T73 Screen Replacement: adım 4, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the four 2mm silver screws located at each of the four corners of the screen.
  5. Asus VivoBook S200E-RHI3T73 Screen Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Gently lift the screen up and over.
    • Use tweezers to remove the EX2 LVDS connector cable that connects the screen and the laptop.
    • Remove the screen.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 2,154
