Ana içeriğe geç
Asus VivoBook S200E-RHI3T73 Touchpad Replacement
Neye ihtiyacın var
  1. Asus VivoBook S200E-RHI3T73 Touchpad Replacement, Touchpad: adım 1, 2 resimden 1. Asus VivoBook S200E-RHI3T73 Touchpad Replacement, Touchpad: adım 1, 2 resimden 2.
    • In order to remove the back lid, you must lay the laptop down with the lid closed and remove the screws with a Phillips #0 screwdriver.
    • There are five 80mm screws.
    • There are four 50mm screws.
    • Pull the back lid off of the laptop using your fingers.
  2. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: adım 2, 2 resimden 1. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: adım 2, 2 resimden 2.
    • There should be a total of twelve 50mm screws when removing the battery.
    • The battery does not have to be fully removed for this step, however the screws must be taken out and the battery lifted.
  3. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: adım 3, 2 resimden 1. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: adım 3, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove the six screws attached to the silver panel.
    • Disconnect the LED ribbon wires using a spudger to lift the clamp.
  4. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: adım 4, 2 resimden 1. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: adım 4, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove the four screws on the silver panel.
    • Using a spudger, gently lift the silver ground strips off of the touch pad.
    • Pull the touch pad up and towards the battery to remove it from the laptop.
Sonuç
Katherine Nasci
124 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S9-G9, Wilson Spring 2019 IUPUI, Team S9-G9, Wilson Spring 2019 üyesi
IUPUI-WILSON-S19S9G9
4 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 780
