Ana içeriğe geç
Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement
Neye ihtiyacın var
  1. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement, Wifi Chip: adım 1, 1 resimden 1.
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the five black 80mm Phillips #0 screws.
    • Remove the four black 50mm Phillips #0 screws.
  2. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement: adım 2, 1 resimden 1.
    • Use a metal spudger to pry the bottom panel open.
    • Be gentle around the edges.
    • Lift the back panel to expose the inside of the laptop.
  3. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement: adım 3, 1 resimden 1.
    • Use a Phillips J0 screwdriver to remove the one black 3mm screw.
  4. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement: adım 4, 1 resimden 1.
    • Use an up and away motion to pull the module out of its slot.
  5. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use precision tweezers to pry the black wire with a gold plug off the main gold plug on the module.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 20
Her zaman: 748
