Ana içeriğe geç
Asus VivoBook X202E-DB21T CMOS Battery Replacement
Neye ihtiyacın var
  1. Asus VivoBook X202E-DB21T CMOS Battery Replacement, Battery: adım 1, 2 resimden 1. Asus VivoBook X202E-DB21T CMOS Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T CMOS Battery Replacement: adım 2, 2 resimden 1. Asus VivoBook X202E-DB21T CMOS Battery Replacement: adım 2, 2 resimden 2.
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T CMOS Battery Replacement: adım 3, 2 resimden 1. Asus VivoBook X202E-DB21T CMOS Battery Replacement: adım 3, 2 resimden 2.
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T CMOS Battery Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T CMOS Battery Replacement: adım 5, 1 resimden 1.
    • Remove the battery from the laptop.
  6. Asus VivoBook X202E-DB21T CMOS Battery Replacement, CMOS Battery: adım 6, 2 resimden 1. Asus VivoBook X202E-DB21T CMOS Battery Replacement, CMOS Battery: adım 6, 2 resimden 2.
    • Unplug and remove the CMOS battery.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 86
Her zaman: 6,337
