Ana içeriğe geç
Asus VivoBook X202E-DB21T Motherboard Replacement
Neye ihtiyacın var
  1. Asus VivoBook X202E-DB21T Motherboard Replacement, Battery: adım 1, 2 resimden 1. Asus VivoBook X202E-DB21T Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 2, 2 resimden 1. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 3, 2 resimden 1. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the battery from the laptop.
  6. Asus VivoBook X202E-DB21T Motherboard Replacement, Hard Drive: adım 6, 2 resimden 1. Asus VivoBook X202E-DB21T Motherboard Replacement, Hard Drive: adım 6, 2 resimden 2.
    • Unscrew the three 4mm screws holding the hard drive to the board.
  7. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 7, 2 resimden 1. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 7, 2 resimden 2.
    • Pull on the tab on the left side of the hard drive and slowly disconnect it from the board.
  8. Asus VivoBook X202E-DB21T Motherboard Replacement, CMOS Battery: adım 8, 2 resimden 1. Asus VivoBook X202E-DB21T Motherboard Replacement, CMOS Battery: adım 8, 2 resimden 2.
    • Unplug and remove the CMOS battery.
  9. Asus VivoBook X202E-DB21T Motherboard Replacement, Motherboard: adım 9, 2 resimden 1. Asus VivoBook X202E-DB21T Motherboard Replacement, Motherboard: adım 9, 2 resimden 2.
    • Unscrew the five 5mm screws holding the left board together.
  10. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 10, 2 resimden 1. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 10, 2 resimden 2.
    • Unplug the two connectors on the left board.
  11. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 11, 3 resimden 1. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 11, 3 resimden 2. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 11, 3 resimden 3.
    • Remove the single 3mm screw from the sound chip.
    • Unplug the sound chip.
    • Remove the sound chip.
  12. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 12, 1 resimden 1.
    • Remove the six 4mm screws holding the fan and CPU cover.
  13. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 13, 2 resimden 1. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 13, 2 resimden 2.
    • Unplug the fan.
    • Remove the fan and CPU cover.
  14. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 14, 1 resimden 1.
    • Unscrew the nine 4mm screws holding the right board together.
  15. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 15, 1 resimden 1.
    • Remove the two remaining connectors on the board.
  16. Asus VivoBook X202E-DB21T Motherboard Replacement: adım 16, 1 resimden 1.
    • Remove the right board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 1,458
