Giriş
Through the course of normal use, it is possible that the in-built speakers in the Asus Vivobook X540SA will become damaged or stop functioning. In this guide, the user will find step-by-step instructions for opening up the device, accessing the speakers, and removing them.
Neye ihtiyacın var
Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
Very carefully, remove the batteries with the blue plastic iFixit opening tool. Focus removing the battery near the highlighted area.
The Disk Drive is located within the upper right hand corner of the laptop.
The Hard Drive is located in the bottom right hand corner. It should be the device covered in black foam.
Bir başkası bu kılavuzu tamamladı.
