Ana içeriğe geç
Asus VivoBook X540SA-BPD0602V Wireless Card Removal
Neye ihtiyacın var
  1. Asus VivoBook X540SA-BPD0602V Wireless Card Removal, Keyboard: adım 1, 1 resimden 1.
    • Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
  2. Asus VivoBook X540SA-BPD0602V Wireless Card Removal: adım 2, 1 resimden 1.
    • Flip the laptop over so the back panel is displayed.
  3. Asus VivoBook X540SA-BPD0602V Wireless Card Removal: adım 3, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
    • Remove the two battery screws (15.6 mm)
    • Two top corner screws (12.5 mm)
    • Six case screws (9.7mm)
  4. Asus VivoBook X540SA-BPD0602V Wireless Card Removal: adım 4, 1 resimden 1.
    • Flip the laptop back over and open it, revealing the screen and keyboard.
  5. Asus VivoBook X540SA-BPD0602V Wireless Card Removal: adım 5, 1 resimden 1.
    • Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
    • When lifting the keyboard panel, do not lift it all the way as the two connection ribbons to the motherboard must be disconnected.
    • It is recommended to break the seal of the case starting at the upper corners closest to the display monitor .
  6. Asus VivoBook X540SA-BPD0602V Wireless Card Removal: adım 6, 1 resimden 1.
    • Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
  7. Asus VivoBook X540SA-BPD0602V Wireless Card Removal, Battery: adım 7, 1 resimden 1.
    • Very carefully, remove the batteries with the blue plastic iFixit opening tool. Focus removing the battery near the highlighted area.
    • The batteries should all be connected to one another and come out of the device as a single unit.
    • Be careful not to rip any of the black plastic covering the batteries. Exposed battery parts can lead to explosions. If the case is ripped, re-wrap them, or properly dispose of them. Do not reuse them.
  8. Asus VivoBook X540SA-BPD0602V Wireless Card Removal, Disk Drive: adım 8, 1 resimden 1.
    • The Disk Drive is located within the upper right hand corner of the laptop.
  9. Asus VivoBook X540SA-BPD0602V Wireless Card Removal: adım 9, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the two screws (5.6 mm) around the disc drive.
    • Note which screws go where. The two smaller screws fasten onto the disc drive, while the three larger screws secure the drive on the outside.
  10. Asus VivoBook X540SA-BPD0602V Wireless Card Removal: adım 10, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the two screws (2.7 mm) on the side of the disc drive fastener.
  11. Asus VivoBook X540SA-BPD0602V Wireless Card Removal: adım 11, 1 resimden 1.
    • After removing the seven screws, lift the metal fastener from the disc drive with the plastic opening tool.
  12. Asus VivoBook X540SA-BPD0602V Wireless Card Removal: adım 12, 1 resimden 1.
    • Slide the disc drive to the right, removing it from the laptop case.
  13. Asus VivoBook X540SA-BPD0602V Wireless Card Removal, Fan: adım 13, 1 resimden 1.
    • The fan is located near the upper left hand corner of the device, connected to the motherboard and right beneath the wireless card.
  14. Asus VivoBook X540SA-BPD0602V Wireless Card Removal: adım 14, 1 resimden 1.
    • There is a bundle of wires connecting the fan to the motherboard. Disconnect them.
  15. Asus VivoBook X540SA-BPD0602V Wireless Card Removal: adım 15, 1 resimden 1.
    • Using the J00 screw bit in the iFixit tool kit, remove the three screws securing the fan to the case. One screw connected to the bottom case (4cm), one connected to the motherboard (4cm), and one screw connected to the Wireless Card (5cm).
  16. Asus VivoBook X540SA-BPD0602V Wireless Card Removal: adım 16, 1 resimden 1.
    • Carefully remove the fan from the case using the blue iFixit opening tool.
  17. Asus VivoBook X540SA-BPD0602V Wireless Card Removal, Wireless Card: adım 17, 1 resimden 1.
    • The wireless cared is located in the upper left portion of the device case, right above the fan and attached to the motherboard.
  18. Asus VivoBook X540SA-BPD0602V Wireless Card Removal: adım 18, 1 resimden 1.
    • There is only one cable connecting the wireless card to the antenna. Disconnect it.
  19. Asus VivoBook X540SA-BPD0602V Wireless Card Removal: adım 19, 1 resimden 1.
    • Carefully slide the wireless card to the right, and remove it from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jessica Browne
978 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G111, Cagle Fall 2017 USF Tampa, Team S1-G111, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S1G111
5 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 32
Her zaman: 1,561
