Ana içeriğe geç
Asus VivoTab RT TF600T Battery Replacement
Neye ihtiyacın var
  1. Asus VivoTab RT TF600T Battery Replacement, Battery: adım 1, 3 resimden 1. Asus VivoTab RT TF600T Battery Replacement, Battery: adım 1, 3 resimden 2. Asus VivoTab RT TF600T Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the tablet is turned off.
    • Remove the tablet from the attached keyboard.
    • To remove the keyboard, simply depress the switch on the left side of the screen and pull the tablet portion off.
  2. Asus VivoTab RT TF600T Battery Replacement: adım 2, 3 resimden 1. Asus VivoTab RT TF600T Battery Replacement: adım 2, 3 resimden 2. Asus VivoTab RT TF600T Battery Replacement: adım 2, 3 resimden 3.
    • Rotate the device 180°, and remove the two 1.59 mm screws at the bottom of the device.
    • Use the Phillips screwdriver size PH000 to remove the two 1.59 mm #000 screws.
  3. Asus VivoTab RT TF600T Battery Replacement: adım 3, 2 resimden 1. Asus VivoTab RT TF600T Battery Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to help detach the screen from the back panel.
    • Insert the plastic opening tool into the bottom right corner and gently start to pry off the screen.
    • Once the screen begins to separate from the body of the device, start working the tool around the outer edges until the entire screen becomes detached.
  4. Asus VivoTab RT TF600T Battery Replacement: adım 4, 2 resimden 1. Asus VivoTab RT TF600T Battery Replacement: adım 4, 2 resimden 2.
    • Now that the screen is completely detached, lay the back panel flat on a smooth surface.
    • Lift the screen to view the inside of the tablet.
  5. Asus VivoTab RT TF600T Battery Replacement: adım 5, 2 resimden 1. Asus VivoTab RT TF600T Battery Replacement: adım 5, 2 resimden 2.
    • Before disconnecting the display cables, turn off the switch labeled DIP; this switch is used to de-energize the system.
    • The battery is connected to the motherboard. To avoid any short circuiting of the device, you must place the switch labeled DIP to OFF.
  6. Asus VivoTab RT TF600T Battery Replacement: adım 6, 3 resimden 1. Asus VivoTab RT TF600T Battery Replacement: adım 6, 3 resimden 2. Asus VivoTab RT TF600T Battery Replacement: adım 6, 3 resimden 3.
    • Remove the yellow tape covering the end of the cables.
  7. Asus VivoTab RT TF600T Battery Replacement: adım 7, 2 resimden 1. Asus VivoTab RT TF600T Battery Replacement: adım 7, 2 resimden 2.
    • After lifting the yellow tape, you should be able to see a white strip. The white strip is actually a lever.
    • Use the plastic opening tool to push in the levers.
  8. Asus VivoTab RT TF600T Battery Replacement: adım 8, 3 resimden 1. Asus VivoTab RT TF600T Battery Replacement: adım 8, 3 resimden 2. Asus VivoTab RT TF600T Battery Replacement: adım 8, 3 resimden 3.
    • With all three white levers pushed in, gently pull on each display cable until the cable disconnects.
  9. Asus VivoTab RT TF600T Battery Replacement: adım 9, 1 resimden 1.
    • Lift the screen upwards to remove.
  10. Asus VivoTab RT TF600T Battery Replacement: adım 10, 3 resimden 1. Asus VivoTab RT TF600T Battery Replacement: adım 10, 3 resimden 2. Asus VivoTab RT TF600T Battery Replacement: adım 10, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Rotate the Tablet clockwise, so that the motherboard is facing away from you.
    • Remove the eleven 0.79 mm #000 screws around the motherboard with the Phillips #000 screwdriver.
    • Remove the two wire connection on the right side of the tablet with the pointed precision tweezers.
    • Be careful the pointed precision tweezers are very sharp.
  11. Asus VivoTab RT TF600T Battery Replacement: adım 11, 3 resimden 1. Asus VivoTab RT TF600T Battery Replacement: adım 11, 3 resimden 2. Asus VivoTab RT TF600T Battery Replacement: adım 11, 3 resimden 3.
    • Use the nylon or metal spudger to help pry the motherboard from the back panel.
    • Once the mother board is relieved from the glue, use your hand to lift the motherboard up and to the opposite end of the back panel.
  12. Asus VivoTab RT TF600T Battery Replacement: adım 12, 3 resimden 1. Asus VivoTab RT TF600T Battery Replacement: adım 12, 3 resimden 2. Asus VivoTab RT TF600T Battery Replacement: adım 12, 3 resimden 3.
    • Use the nylon or metal spudger to pry the battery from the back panel.
  13. Asus VivoTab RT TF600T Battery Replacement: adım 13, 2 resimden 1. Asus VivoTab RT TF600T Battery Replacement: adım 13, 2 resimden 2.
    • Gently lift the battery over its connection prongs with both hands.
    • Remove the battery and replace it.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Brittany
490 İtibar
2 adet Kılavuz yazıldı
Ekip
Bir Yorum
Hi...Im trying to disconnect battery and reconnect like pics above to try a reset from black screen of death after updates...I have black screen..it was working fine until then..now I dont even get a power light to show its charging????
michaeljohnjacobs8 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 2,995
