Ana içeriğe geç
Asus VivoTab Smart Camera Replacement
Neye ihtiyacın var
  1. Asus VivoTab Smart Camera Replacement, Motherboard: adım 1, 3 resimden 1. Asus VivoTab Smart Camera Replacement, Motherboard: adım 1, 3 resimden 2. Asus VivoTab Smart Camera Replacement, Motherboard: adım 1, 3 resimden 3.
    • Power off the device before you begin disassembly.
    • Place the device face down on a flat surface.
    • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
  2. Asus VivoTab Smart Camera Replacement: adım 2, 3 resimden 1. Asus VivoTab Smart Camera Replacement: adım 2, 3 resimden 2. Asus VivoTab Smart Camera Replacement: adım 2, 3 resimden 3.
    • Unplug the ribbon that connects to the camera by pulling outward on it with tweezers.
    • Remove the silver plate that sits on top of the camera lens.
  3. Asus VivoTab Smart Camera Replacement: adım 3, 3 resimden 1. Asus VivoTab Smart Camera Replacement: adım 3, 3 resimden 2. Asus VivoTab Smart Camera Replacement: adım 3, 3 resimden 3.
    • Use tweezers to grab the speaker cable near the white plug and pull to disconnect it.
  4. Asus VivoTab Smart Camera Replacement: adım 4, 2 resimden 1. Asus VivoTab Smart Camera Replacement: adım 4, 2 resimden 2.
    • Gently pull outward on the ribbon to with tweezers to disconnect it.
  5. Asus VivoTab Smart Camera Replacement: adım 5, 3 resimden 1. Asus VivoTab Smart Camera Replacement: adım 5, 3 resimden 2. Asus VivoTab Smart Camera Replacement: adım 5, 3 resimden 3.
    • Peel back the tape covering the ribbons.
  6. Asus VivoTab Smart Camera Replacement: adım 6, 3 resimden 1. Asus VivoTab Smart Camera Replacement: adım 6, 3 resimden 2. Asus VivoTab Smart Camera Replacement: adım 6, 3 resimden 3.
    • Unplug the 3 ribbons by pulling outward on them with a pair of tweezers.
  7. Asus VivoTab Smart Camera Replacement: adım 7, 3 resimden 1. Asus VivoTab Smart Camera Replacement: adım 7, 3 resimden 2. Asus VivoTab Smart Camera Replacement: adım 7, 3 resimden 3.
    • Remove two 2.7 mm Phillips #00 screws holding down the pressure plate.
    • Use tweezers to lift back the battery connector, which is located directly under the pressure plate.
  8. Asus VivoTab Smart Camera Replacement: adım 8, 2 resimden 1. Asus VivoTab Smart Camera Replacement: adım 8, 2 resimden 2.
    • Remove seven 3.7 mm Phillips #00 screws.
    • Remove one 2.7 mm Phillips #00 screw.
  9. Asus VivoTab Smart Camera Replacement: adım 9, 2 resimden 1. Asus VivoTab Smart Camera Replacement: adım 9, 2 resimden 2.
    • Slide the tweezers under the motherboard and lift up to remove the motherboard.
  10. Asus VivoTab Smart Camera Replacement, Camera: adım 10, 1 resimden 1.
    • Flip the motherboard over and lay it flat on a surface
  11. Asus VivoTab Smart Camera Replacement: adım 11, 2 resimden 1. Asus VivoTab Smart Camera Replacement: adım 11, 2 resimden 2.
    • Use tweezers to gently lift and remove the camera from the motherboard.
Sonuç
Zach Hatten
548 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-4, Sullivan Fall 2016 USF Tampa, Team 2-4, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S2G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 308
