Ana içeriğe geç
Giriş
This guide will show you how to remove the back panel of the Asus VivoTab Smart and replace the speaker. You can find the necessary tools for this project in the tools section below.
  1. Power off the device before you begin disassembly. Place the device face down on a flat surface. Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
    • Power off the device before you begin disassembly.
    • Place the device face down on a flat surface.
    • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
  2. Take care not to break the speaker wire when unplugging it from the device. Carefully unplug the speaker wire from the device by grabbing the wire near the white plug with tweezers and pulling gently. Carefully unplug the speaker wire from the device by grabbing the wire near the white plug with tweezers and pulling gently.
    • Take care not to break the speaker wire when unplugging it from the device.
    • Carefully unplug the speaker wire from the device by grabbing the wire near the white plug with tweezers and pulling gently.
  3. Android Tamir Setleri
    Yeni bir ekran veya pil, bir tamir kiti kadar yakınında.
    Hemen Alışveriş Yapın
  4. Remove two 2.7 mm Phillips #00 screws. Remove two 3.7 mm Phillips #00  screws.
    • Remove two 2.7 mm Phillips #00 screws.
    • Remove two 3.7 mm Phillips #00 screws.
  5. Remove the speaker from the device by lifting up on it.
    • Remove the speaker from the device by lifting up on it.
Sonuç
Zach Hatten
548 İtibar
4 adet Kılavuz yazıldı
Takım
USF Tampa, Team 2-4, Sullivan Fall 2016 USF Tampa, Team 2-4, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S2G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
Her zaman: 153
