Ana içeriğe geç
Asus Vivobook Flip 14 TP410U LCD Assembly Replacement
Neye ihtiyacın var
  1. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement, LCD Assembly: adım 1, 1 resimden 1.
    • Turn off the power and disconnected the AC cable from the laptop.
  2. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: adım 2, 2 resimden 1. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: adım 2, 2 resimden 2.
    • Remove the rubber covers for the two screws located at the bottom of the screen.
    • Use a Phillips #00 screwdriver to remove the two 6.4 mm screws outlined in the image.
  3. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: adım 3, 2 resimden 1. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: adım 3, 2 resimden 2.
    • Excessive force may cause damage to connections.
    • Rotate the screen 360 degrees for ease of access.
    • Place the opening tool at the corner of where the screen meets the base of the laptop.
    • Pry open the screen along the edge until it is completely off the front cover.
    • Disconnect each appropriate connector while opening up the laptop.
  4. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: adım 4, 2 resimden 1. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: adım 4, 2 resimden 2.
    • Excessive force should avoided since damage may accrue.
    • Remove the cable that connects to the touch display, front camera, and motherboard.
    • Remove each piece of tape that holds down each cable.
  5. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: adım 5, 1 resimden 1.
    • Have the new LCD display fully unboxed and ready to be used.
    • Remove the old LCD display.
    • The touch screen sensor is extremely fragile, make sure to not put excessive force on the cable while assembling.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dominic Bento
305 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 49
Her zaman: 815
