Ana içeriğe geç
Asus Vivobook Max X541SA-PD0703X CD drive Replacement
Neye ihtiyacın var
  1. Asus Vivobook Max X541SA-PD0703X CD drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: adım 2, 1 resimden 1.
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: adım 3, 3 resimden 1. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: adım 3, 3 resimden 2. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: adım 3, 3 resimden 3.
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: adım 4, 3 resimden 1. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: adım 4, 3 resimden 2. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: adım 4, 3 resimden 3.
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: adım 5, 1 resimden 1.
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: adım 6, 2 resimden 1. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: adım 6, 2 resimden 2.
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: adım 7, 1 resimden 1.
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
  8. Asus Vivobook Max X541SA-PD0703X CD drive Replacement, Disc Drive: adım 8, 1 resimden 1.
    • Remove the disc drive by sliding it towards the right and removing it from the laptop case
Sonuç
Mayar Eskandarani
385 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Cagle Spring 2018 USF Tampa, Team S1-G4, Cagle Spring 2018 üyesi
USFT-CAGLE-S18S1G4
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 738
