Ana içeriğe geç
Asus Vivobook Max X541SA-PD0703X Track Pad Replacement
Neye ihtiyacın var
  1. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement, Keyboard: adım 1, 1 resimden 1.
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: adım 2, 1 resimden 1.
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: adım 3, 2 resimden 1. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: adım 3, 2 resimden 2.
    • Using a plastic opening tool, pry up the palm rest form the bottom half of the laptop.
    • Ribbon cables connect the two half so don't remove completely.
  4. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: adım 4, 3 resimden 1. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: adım 4, 3 resimden 2. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: adım 4, 3 resimden 3.
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: adım 5, 1 resimden 1.
    • Take the keyboard half of the laptop and place it in front of you so that they keys are facing down.
  6. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: adım 6, 1 resimden 1.
    • Remove the three 3mm Phillips #0 screws from the touchpad.
  7. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: adım 7, 1 resimden 1.
    • Use a spudger to flip up the retaining flap on the touch pad ribbon cable ZIF socket.
    • Pull the ribbon out of the socket.
  8. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: adım 8, 2 resimden 1. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: adım 8, 2 resimden 2.
    • Remove the touchpad.
Sonuç
Hetvi Mehta
781 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Cagle Spring 2018 USF Tampa, Team S1-G4, Cagle Spring 2018 üyesi
USFT-CAGLE-S18S1G4
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 479
