Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip the device over so that the back cover is facing you.
Remove the four 5mm Phillips #1 screws from the top of the laptop.
Remove the two 6mm Phillips #1 screws from the sides of the laptop.
Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
Lift off the cover and remove the back cover from the device.
Using a Phillips #1 Screwdriver remove the six 3 mm screws keeping the battery in place.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Outstanding instructions in replacing this battery. Very easy. Thanks!!
