Ana içeriğe geç
Asus Vivobook Q302LA-BHI3T09 Battery Replacement
Neye ihtiyacın var
  1. Asus Vivobook Q302LA-BHI3T09 Battery Replacement, Battery: adım 1, 2 resimden 1. Asus Vivobook Q302LA-BHI3T09 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Before doing a replacement, make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place.
  2. Asus Vivobook Q302LA-BHI3T09 Battery Replacement: adım 2, 2 resimden 1. Asus Vivobook Q302LA-BHI3T09 Battery Replacement: adım 2, 2 resimden 2.
    • Pry open the back casing using the opening tool along the side crevice.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus Vivobook Q302LA-BHI3T09 Battery Replacement: adım 3, 2 resimden 1. Asus Vivobook Q302LA-BHI3T09 Battery Replacement: adım 3, 2 resimden 2.
    • Using the JIS #0 Screwdriver, remove the five 5.0 mm screws that hold down the battery.
  4. Asus Vivobook Q302LA-BHI3T09 Battery Replacement: adım 4, 2 resimden 1. Asus Vivobook Q302LA-BHI3T09 Battery Replacement: adım 4, 2 resimden 2.
    • Disconnect the cable connected to the motherboard.
    • To remove, lift the ends using the opening tool.
Sonuç
Aymane Elbernoussi
160 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G5, Eyestone Spring 2018 USF Tampa, Team S5-G5, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S5G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 525
