Ana içeriğe geç
Asus W2W-A1 Fan Replacement
Neye ihtiyacın var
  1. Asus W2W-A1 Fan Replacement, Keyboard: adım 1, 3 resimden 1. Asus W2W-A1 Fan Replacement, Keyboard: adım 1, 3 resimden 2. Asus W2W-A1 Fan Replacement, Keyboard: adım 1, 3 resimden 3.
    • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
    • Unscrew the 2 4 mm Phillips head screws by the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Asus W2W-A1 Fan Replacement: adım 2, 1 resimden 1.
    • Remove the panel above the keyboard with a plastic spudger.
    FixBot'a Sor
    Yorum Ekle
  3. Asus W2W-A1 Fan Replacement: adım 3, 1 resimden 1.
    • Once the panel is removed, use the spudger to pry out the keyboard.
    • Do not fully remove, for the keyboard is still attached to the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  4. Asus W2W-A1 Fan Replacement: adım 4, 2 resimden 1. Asus W2W-A1 Fan Replacement: adım 4, 2 resimden 2.
    • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
    • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Now you can fully remove the keyboard from the laptop.
    FixBot'a Sor
    Yorum Ekle
  5. Asus W2W-A1 Fan Replacement, Front Panel: adım 5, 1 resimden 1.
    • Place your fingers or a spudger between the front panel and the rest of the laptop.
    • Pull upwards gently to detach the side you are grabbing.
    • Repeat on the other side until the panel easily peels off the laptop.
    FixBot'a Sor
    Yorum Ekle
  6. Asus W2W-A1 Fan Replacement, Touchpad: adım 6, 2 resimden 1. Asus W2W-A1 Fan Replacement, Touchpad: adım 6, 2 resimden 2.
    • The touchpad should be loosely attached to the rest of the laptop by a ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  7. Asus W2W-A1 Fan Replacement: adım 7, 1 resimden 1.
    • Gently pull the ribbon cable out of its socket attached to the touchpad.
    • You are now able to remove the touchpad.
    FixBot'a Sor
    Yorum Ekle
  8. Asus W2W-A1 Fan Replacement, Protective Cover: adım 8, 1 resimden 1.
    • Unscrew the 3 13 mm Phillips screws on the surface of the panel.
    • Unscrew the 4 mm Phillips screw beneath the panel.
    FixBot'a Sor
    Yorum Ekle
  9. Asus W2W-A1 Fan Replacement: adım 9, 3 resimden 1. Asus W2W-A1 Fan Replacement: adım 9, 3 resimden 2. Asus W2W-A1 Fan Replacement: adım 9, 3 resimden 3.
    • There are many different types of screws in this step so make sure to arrange the screws by their different sizes.
    • Unscrew the six 17 mm Phillips head screws on the stands on the back and the 2 "A" screws of the same size adjacent to the stands.
    • Unscrew the two C Phillips head screws on the hard drive panel. There is also one more C screw in the upper right corner of the laptop as shown.
    • Unscrew the eight 8mm lock phillips screws and the screws along the outside of the laptop.
    • Unscrew the three 3mm E Phillips screw and the one 3mm D Phillips screw.
    • Unscrew the 5mm Phillips head screw that lies just above the D screw.
    FixBot'a Sor
    Yorum Ekle
  10. Asus W2W-A1 Fan Replacement: adım 10, 1 resimden 1.
    • Unscrew the two 8 mm Phillips screws beneath the hard drive panel.
    • After finishing this step, flip the laptop over.
    FixBot'a Sor
    Yorum Ekle
  11. Asus W2W-A1 Fan Replacement: adım 11, 1 resimden 1.
    • Everything should now be loose enough for you to start removing the panel.
    • Do not fully remove the panel, for there are still ribbons attached on the inside.
    FixBot'a Sor
    Yorum Ekle
  12. Asus W2W-A1 Fan Replacement: adım 12, 1 resimden 1.
    • Carefully remove the ribbons from the base.
    • Then you can lift the panel to access the components beneath.
    FixBot'a Sor
    Yorum Ekle
  13. Asus W2W-A1 Fan Replacement, Fan: adım 13, 2 resimden 1. Asus W2W-A1 Fan Replacement, Fan: adım 13, 2 resimden 2.
    • Remove the 3 4 mm Phillips head screws holding down the fan on inside of the laptop.
    FixBot'a Sor
    Yorum Ekle
  14. Asus W2W-A1 Fan Replacement: adım 14, 1 resimden 1.
    • Remove the 4 mm Phillips head screw holding the left panel on the back of the laptop.
    • Slide off the left panel by pulling to the left.
    FixBot'a Sor
    Yorum Ekle
  15. Asus W2W-A1 Fan Replacement: adım 15, 2 resimden 1. Asus W2W-A1 Fan Replacement: adım 15, 2 resimden 2.
    • Remove the 4 4 mm Phillips screws on the orange cooling system.
    FixBot'a Sor
    Yorum Ekle
  16. Asus W2W-A1 Fan Replacement: adım 16, 1 resimden 1.
    • Gently lift the orange cooling system upward to remove it from the laptop.
    FixBot'a Sor
    Yorum Ekle
  17. Asus W2W-A1 Fan Replacement: adım 17, 2 resimden 1. Asus W2W-A1 Fan Replacement: adım 17, 2 resimden 2.
    • Disconnect the cable from its socket by pulling up on it gently. It will be revealed beneath the previously removed cooling system.
    FixBot'a Sor
    Yorum Ekle
  18. Asus W2W-A1 Fan Replacement: adım 18, 2 resimden 1. Asus W2W-A1 Fan Replacement: adım 18, 2 resimden 2.
    • From the front of the laptop, remove the tape holding down the fan's cable.
    • Gently push down on the protective area around the fan as shown to pull the cable through the gap created.
    • Lift the fan out of the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Emily Mullins
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-29, Maness Spring 2014 Cal Poly, Team 13-29, Maness Spring 2014 üyesi
CPSU-MANESS-S14S13G29
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 43
Her zaman: 713
