Ana içeriğe geç
Asus W2W-A1 Hard Drive Replacement
Neye ihtiyacın var
    1. Asus W2W-A1 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
      • Before disassembly, make sure the laptop is powered off and the battery is disconnected.
      • Remove the two screws (size?) on the lower panel at the bottom of the laptop (identify tool to use).
      FixBot'a Sor
      Yorum Ekle
    2. Asus W2W-A1 Hard Drive Replacement: adım 2, 1 resimden 1.
      • Grab the panel and lift upwards while pulling towards yourself.
      FixBot'a Sor
      Yorum Ekle
    3. Asus W2W-A1 Hard Drive Replacement: adım 3, 1 resimden 1.
      • Remove the 3 4 mm Phillips upper screws holding the hard drive down.
      FixBot'a Sor
      Yorum Ekle
    4. Asus W2W-A1 Hard Drive Replacement: adım 4, 1 resimden 1.
      • Pull the hard drive towards yourself to disconnect it from the laptop.
      FixBot'a Sor
      Yorum Ekle
    5. Asus W2W-A1 Hard Drive Replacement: adım 5, 1 resimden 1.
      • Lift the hard drive upwards to remove it from the laptop.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Nolan Schock
501 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-29, Maness Spring 2014 Cal Poly, Team 13-29, Maness Spring 2014 üyesi
CPSU-MANESS-S14S13G29
4 Üyeler
72 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 44
Her zaman: 558
