Ana içeriğe geç
Asus W2W-A1 Touchpad Replacement
Neye ihtiyacın var
    1. Asus W2W-A1 Touchpad Replacement, Keyboard: adım 1, 3 resimden 1. Asus W2W-A1 Touchpad Replacement, Keyboard: adım 1, 3 resimden 2. Asus W2W-A1 Touchpad Replacement, Keyboard: adım 1, 3 resimden 3.
      • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
      • Unscrew the 2 4 mm Phillips head screws by the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Asus W2W-A1 Touchpad Replacement: adım 2, 1 resimden 1.
      • Remove the panel above the keyboard with a plastic spudger.
      FixBot'a Sor
      Yorum Ekle
    3. Asus W2W-A1 Touchpad Replacement: adım 3, 1 resimden 1.
      • Once the panel is removed, use the spudger to pry out the keyboard.
      • Do not fully remove, for the keyboard is still attached to the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    4. Asus W2W-A1 Touchpad Replacement: adım 4, 2 resimden 1. Asus W2W-A1 Touchpad Replacement: adım 4, 2 resimden 2.
      • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
      • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
      • Now you can fully remove the keyboard from the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Asus W2W-A1 Touchpad Replacement, Front Panel: adım 5, 1 resimden 1.
      • Place your fingers or a spudger between the front panel and the rest of the laptop.
      • Pull upwards gently to detach the side you are grabbing.
      • Repeat on the other side until the panel easily peels off the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Asus W2W-A1 Touchpad Replacement, Touchpad: adım 6, 2 resimden 1. Asus W2W-A1 Touchpad Replacement, Touchpad: adım 6, 2 resimden 2.
      • The touchpad should be loosely attached to the rest of the laptop by a ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    2. Asus W2W-A1 Touchpad Replacement: adım 7, 1 resimden 1.
      • Gently pull the ribbon cable out of its socket attached to the touchpad.
      • You are now able to remove the touchpad.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Nolan Schock
501 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-29, Maness Spring 2014 Cal Poly, Team 13-29, Maness Spring 2014 üyesi
CPSU-MANESS-S14S13G29
4 Üyeler
80 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 510
