Giriş
This guide will show you how to replace the battery of the Asus X200CA. The battery is a 3Cells 3300 mAh 33 Whrs.
Neye ihtiyacın var
Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
Remove the black 14.5mm screw from the center of the bottom cover.
Use a Phillips #00 screwdriver to remove the black 4.7mm screw holding the battery in place.
11 farklı kişi bu kılavuzu tamamladı.
