Ana içeriğe geç
Asus X200CA Display Replacement
Neye ihtiyacın var
  1. Asus X200CA Display Replacement, Display: adım 1, 1 resimden 1.
    • Wedge a metal spudger between the bezel and display cover.
    • Slide the metal spudger back and forth along the top, left, and right sides to pry apart the screen from the outer shell.
  2. Asus X200CA Display Replacement: adım 2, 2 resimden 1. Asus X200CA Display Replacement: adım 2, 2 resimden 2.
    • Remove the six silver 2.7 mm screws securing the screen bracket to the screen bezel.
  3. Asus X200CA Display Replacement: adım 3, 2 resimden 1. Asus X200CA Display Replacement: adım 3, 2 resimden 2.
    • Slice the silver foil tape with a spudger by applying pressure between the frame and the back of the screen case.
  4. Asus X200CA Display Replacement: adım 4, 1 resimden 1.
    • Pull apart the black fabric tape with your fingers.
  5. Asus X200CA Display Replacement: adım 5, 2 resimden 1. Asus X200CA Display Replacement: adım 5, 2 resimden 2.
    • Use an opening tool to peel off the sticker label securing the LCD cable to the LCD display.
    • Gently pull the sticker to disconnect the LCD cable.
    • Potential for device damage: Do not use excessive force while removing the video cable attached to the back of the LCD.
  6. Asus X200CA Display Replacement: adım 6, 1 resimden 1.
    • Lift the LCD screen to remove it from the device.
  7. Asus X200CA Display Replacement: adım 7, 3 resimden 1. Asus X200CA Display Replacement: adım 7, 3 resimden 2. Asus X200CA Display Replacement: adım 7, 3 resimden 3.
    • Remove the four silver 2.7 mm screws to separate the LCD screen from the two screen brackets.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jacqueline Collier
1.047 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Leahy Fall 2017 USF Tampa, Team S1-G2, Leahy Fall 2017 üyesi
USFT-LEAHY-F17S1G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 1,766
