Ana içeriğe geç
Asus X200CA Keyboard Replacement
Neye ihtiyacın var
  1. Asus X200CA Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. Asus X200CA Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Keyboard Replacement: adım 2, 1 resimden 1.
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Keyboard Replacement: adım 3, 1 resimden 1.
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Jacqueline Collier
1.047 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Leahy Fall 2017 USF Tampa, Team S1-G2, Leahy Fall 2017 üyesi
USFT-LEAHY-F17S1G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 1,052
