Ana içeriğe geç
Asus X200CA-HCL 1104G Motherboard Replacement
Neye ihtiyacın var
  1. Asus X200CA-HCL 1104G Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Asus X200CA-HCL 1104G Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • Pry open the Keyboard/Touch pad.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  2. Asus X200CA-HCL 1104G Motherboard Replacement: adım 2, 1 resimden 1.
    • Detach keyboard and touch screen cables
    • These are the cable that are holding the keyboard and touch screen together
  3. Asus X200CA-HCL 1104G Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the following four screws: Four 4 mm Phillips #0 using a phillips screwdriver.
    • Slide out the hard drive
  4. Asus X200CA-HCL 1104G Motherboard Replacement: adım 5, 1 resimden 1.
    • Detach speaker
  5. Asus X200CA-HCL 1104G Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove motherboard screws
    • These would be located on the green panel which is the motherboard
    • Carefully remove motherboard
Sonuç
Svetlana Pimentel
201 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 UMass Dartmouth, Team S1-G2, Simcock Fall 2017 üyesi
UMASSD-SIMCOCK-F17S1G2
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 407
