Ana içeriğe geç
Asus X200CA-HCL 1104G Speaker Replacement
Neye ihtiyacın var
  1. Asus X200CA-HCL 1104G Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • Pry open the Keyboard/Touch pad.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  2. Asus X200CA-HCL 1104G Speaker Replacement: adım 2, 1 resimden 1.
    • Detach keyboard and touch screen cables
    • These are the cable that are holding the keyboard and touch screen together
  3. Asus X200CA-HCL 1104G Speaker Replacement: adım 3, 1 resimden 1.
    • Unclip the connector that is located above touch screen
  4. Asus X200CA-HCL 1104G Speaker Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to remove the speaker bar that is located beneath the touch screen.
    • Once removed carefully disconnect the clip to the left of the speaker.
Sonuç
Svetlana Pimentel
201 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 UMass Dartmouth, Team S1-G2, Simcock Fall 2017 üyesi
UMASSD-SIMCOCK-F17S1G2
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 296
