Ana içeriğe geç
Asus X200MA Battery Replacement
Neye ihtiyacın var
  1. Asus X200MA Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Battery Replacement: adım 2, 1 resimden 1.
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Battery Replacement: adım 3, 1 resimden 1.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Battery Replacement, Battery: adım 4, 1 resimden 1.
  5. Asus X200MA Battery Replacement: adım 5, 1 resimden 1.
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Battery Replacement: adım 6, 1 resimden 1.
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Battery Replacement: adım 7, 1 resimden 1.
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Battery Replacement: adım 8, 1 resimden 1.
    • Slide the battery up and out.
Sonuç
29 farklı kişi bu kılavuzu tamamladı.
Vanessa Garcia
1.763 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-24, Maness Winter 2015 Cal Poly, Team 21-24, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G24
4 Üyeler
8 adet Kılavuz yazıldı
8 Yorum
Thanks for the write up! Easy to follow, Great photos, and worked great!
nathaniel forward - Yanıt
thanks it worked
iqbal nasution - Yanıt
Your step by step instructions were so easy to follow. Great job. Thanks! :)
Fernando H - Yanıt
I would like to buy a battery to it, Please suggest me the best portal site
jagadeeshkumar maddala - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 27
Son 30 gün: 71
Her zaman: 35,366
