Parçalar
Hiçbir parçaya gerek yok.
  1. Remove the following six screws:
    • Remove the following six screws:
    • Six 4 mm Phillips #0 using a phillips scredriver
    • Remove the following one screw:
    • One 14 mm Phillips #0 using a phillips screwdriver
    • The 14mm screw goes in the center.
  2. Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Remove the black foam and adhesive located on top of the hard drive.
    • Remove the black foam and adhesive located on top of the hard drive.
  5. Remove the following four screws:
    • Remove the following four screws:
    • Four 4 mm Phillips #0 using a phillips screwdriver.
  6. Slide out the hard drive
    • Slide out the hard drive
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Vanessa Garcia
1.550 İtibar
6 adet Kılavuz yazıldı
Takım
Cal Poly, Team 21-24, Maness Winter 2015 Cal Poly, Team 21-24, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G24
4 Üyeler
Bir Yorum
You FORGOT TO MENTION that one must remove the 2 Rubber feet to get at 2 more screws :-(((((((
Matthew Miller - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 Gün: 19
Son 30 Gün: 78
Her zaman: 6,771
