Ana içeriğe geç
Asus X200MA Keyboard Assembly Replacement
Neye ihtiyacın var
  1. Asus X200MA Keyboard Assembly Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Keyboard Assembly Replacement: adım 2, 1 resimden 1.
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Keyboard Assembly Replacement: adım 3, 1 resimden 1.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Vanessa Garcia
1.763 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-24, Maness Winter 2015 Cal Poly, Team 21-24, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G24
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 17
Her zaman: 2,567
